<div class='quotetop'>QUOTE(foggy @ Jan 1 2007, 10:18 PM) [snapback]78028[/snapback]</div>
if you do alot of offroading- deep mud, I would suggest going with a magnacharger.
SAME AS FOGGY SAID. SC THAT BAD BOY IF YOUR OFF ROAD'IN. USE A WATER TO WATER INTERCOOLER BY THE MOTOR OR UNDER THE RADIX. THEN MUD ALL YOU WANT. IT WILL HAVE TONS OF LOW END TORQUE. JUST WHAT YOU NEED FOR MUDD'IN.
JAMEST
12 Sec. Club! SOLD
SOLD***
