Thanks for the info everyone. I appreciate it. I got the old bastard running this morning. I just have to work out a few bugs now
1989 K1500, 33's, LQ4 swap in the works
1991 Mustang GT, Solid lifter 347, GR40 suspension
1972 Triumph Tiger hard tail bobber
Sorry
But how did you end up hooking up to the alternator?
Im using the alternator from the donor truck and of course has a different plug connector. Do i just cut the original connector or use the 90's model alternator?
No need to apologize, man. What I like about this board is how everyone helps each other out.
I actually didn't hook it up to anything yet. The battery light wasn't illuminated so I just left it go. If it comes on or there are any adverse problems, I'm going to try connecting it to the brown wire that plugs into the top of the lq4 alt.
When you do your lsx harness, just make sure you don't clip off the alt plug
Look in my sig and you will see a link to the 6.0 service manual if you need it for anything.
Been lurking since 09 and I finally have my kickass 6.0 LQ4LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
Thanks guys
I went ahead and managed to get the original alternator on there.
