Looks good! What size are the front runners?
maybe one day i will have both the fenders and the bed on. starting to look like a truck again! cant mount the tire because the it's stuffed into the frame. should sit perfect with the wider 8.8. spacers will work until then. the rear end should drop some more after the 16 gallon fuel cell, battery relocation and rear bumper. also the spring sliders will drop it another 1/2" or so. i want to throw the front fenders on but i have a ton of cleaning to do on the garage now that i have it back.
I have the same IR air compressor...
Nice Work !
04' RCSB, LQ9, Front mount T76, TU1, Circle D 3K, Built 4L60E, True Trac, 3.42:1, 4-6 Drop
Lookin mean!
99 rcsb silverado...... boosted.
Nice dime, this thread makes me miss my 350 .40 over 84 s10 blazer.
I like the updated front end, I always hated the sealed beams on the 2nd gen. S10s
Maybe after I finish my current project ill find another first gen blaze.
I have a question for you tho, who's your tranny guy?
I need my tranny built and don't know/trust any trans shops locally. Im close enough to Houston to make a quick drive up there.
Pm me with some info if you don't mind.
it started out as a lvl7 65e from FLT. it needed new clutches so i sent it to Vince B on pt.net for the rebuild/transbrake and extra billet internals. Vince originally built it for FLT, and has put his own touches inside of it since then, so it is now officially a Vince B transmission B)
