Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 62
Thread: Finally, my 1994 Silverado LSX swap thread!
    Nov 2011
    Stuart, FL
    It's about time I start this thing!
    1994 Silverado stepside currently with a 350 TIB and 4L60E
    My soon to be Sleeper
    Engine and trans parts that are going in:
    862 heads milled 0.015, 45 degree cut valves and with LS6 springs
    Edelbrock Performer RPM Carb'd LS1 Intake manifold
    Holley 750cfm double pumper carb
    Holley Fuel pressure regulator
    Comp cams Thumpr Cam
    MSD 6LS ignition
    Dirty Dingo engine mounts
    LT Headers 2" primary's baby (thanks to DBRODS)
    (2) SLP Loudmouth mufflers
    GM flywheel adapter with longer bolts to use my early 4L60E, thats right a carb with a 4L60E.
    Transgo HD2 Shift Kit and Corvette servo
    And some pics for yall
    Nov 2011
    Stuart, FL
    Nov 2011
    Stuart, FL
    Nov 2011
    Stuart, FL
    Nov 2011
    Stuart, FL
    So thats it for now, I am probably going to remove the oil pan tonight and clean it. Then I will paint the block and install the cam. It's finally moving along.
    Feb 2011
    Barnwell, SC
    Where did you get the motor from? The bottom of a lake? Jk. Looking good. I kinda wish I would have done some painting on mine now.
    Nov 2011
    Stuart, FL
    Quote Originally Posted by bstill View Post
    LOL, It took me awhile to find where the oil leak came from and then I found this:
    There was a hole in the timing cover that was poorly covered with gasket sealer.
    Ponca City
    That's some awsome cleaning lol
    Slowest in Oklahoma...
    Nov 2011
    Stuart, FL
    Quote Originally Posted by ecld_07 View Post
    I hate detail work so this has taken alot for me to do, but I will be happier and proud when it is done.
    Jan 2012
    warwick ny
    What did you use to clean the top of the pistons? They came out nice.
