i swapped a 6.0 into my 93 yukon, the first year of the 4l60e. all you need to do is get a 1995+ wiring harness for inside the trans that comes with the round 20 pin plug and a tcc pwm solenoid. There is an extra pin in there for the torque converter clutch pulse width modulated solenoid. If you are standing under your truck facing the rear, the solenoid goes into the hole closest to you and on the left. The new harness has an additional plug right there for the solenoid. You can also have it programmed out i believe but i thought it was easier to just get a $14.99 4l60e harness from ebay and a free used solenoid by chatting up a tech at a local chevy dealer. Been a few months and no issues or codes so I would say it works, at least as far as the pcm is concerned. I think the pump is different also for the pwm, but like i said, mine works just fine.
1993 GMC Yukon GT, 6.0 vortec, head work, no cats, cai, HpTuned by me, jasper lvl2 4l65e, nbs brake conversion
