Results 1 to 9 of 9
Thread: my 4l60e is junk
    my 4l60e is junk
    well heres the problem , my tranny's acting up on 1st to 2nd . when it's in 1st and rpms get to about 3500 i can feel it slipping ,then it will shift into second and keep slipping till rpms come up then goes into gear, 3rd and 4th work just fine . any ideas of what might be causing this other than it being a 4l60e? thanx in advance
    Woodstock, CT
    The 1-2 clutch pack is most likely smoked. 4L60E isnt a bad transmission at all, it just needs to be built right and they can easily handle 450-550 horsepower and be reliable.
    1999 RCSB, 4X4, 260k miles, LQ9, XER281HR cam, port+polis+shaved LS1 heads, LS6 intake, VHR tune, Manthorne Motorsports 4L60E Transmission, SLP Und-Pulley, Camaro E-fans, Yank TB4000 converter
    http://www.manthornemotorsports.com
    Buffalo or Rochester, New York
    Mine is doing the same thing but I think it's because I towed 10,000 lbs with it. Shoulda bought a 2500HD
    Kyle - 2004 K1500 Z71 RCSB 5.3
    - Nelson 93 Octane Tune - LPP Long Tubes + Y - Gibson Extreme Duals - Cut Up Stock Air Box - 10.95 @ 67 in the 1/8 -
    - '05 Pickup Front Brakes - '05 Suburban Rear Brakes - Russel Stainless Braided Hoses -
    - DTRL's Turned to Park Lights - 4-HI Mod - '05 SS Seats -
    - I downshift near hybrids so they can hear me hurting the environment. -
    well had the tranny rebuilt . and guess what ? now 3rd 4th are gone, i was on my way home from work as i was going over a bridge it went to down shift then it lost 3rd and 4th . any ideas ?
    its dead. new 3-4 clutches and other work needed to fix it right next time.
    hope it just needs clutches . i did use altos red hps for all the clucth pack . are they junk or maybe just bad luck on the rebuild .
    make sure you use the correct valve body gaskets. Wrong one will blow your 3/4 pack IIRC. You may have a leak somewhere in the input drum, leaking at a seal or the input shaft. Make sure you didn't nick any of the seals in the front drum.
    I stick to BorgWarner clutches FWIW
    let's see what bs the rebuilder gives me .
