Results 1 to 2 of 2
Thread: 8.5 and 8.625 Carrier Swap info
    Oct 2007
    Manchester, NH
    So I finally go around to install my Gov-loc unit that I got for free from an 03 Z71 Avalanche.
    Now, since I used a 8.625 Carrier in my old 8.5 Rear end, diffrent bearings were required to perform the swap. See info here: (or below)
    8.5 and 8.625 Swap info
    I got the rear carrrier installed and reinstalled my original 3.08 gears. Then installed my T/A Performance cover. Now, this cover in my case is pretty much a band-aid on a bullet wound. But here is my break down on cost.
    Pinion Bearings-Looked fine when disassembled. Reuse as well as pinion seal.
    Gov-Loc unit- FREE
    "Swap" carrier bearings-$45
    3.08 Gears- FREE
    T/A Performance cover- $155
    GM Synthetic Gear lube- FREE
    Axle shafts and axle bearings/seals- Fine, reused.
    So, I have $200 total into this rearend. Lets see how long it will last launching off the Transbrake. I'm gonna guess not very..........
    Installing the RH axle shaft, I accidently hit my truck with it. Chipped the paint right to the metal. ****!
    Mid year 1999 GM switched from the 8.5" axle to the 8.625" axle.
    The difference between the 8.5" and the 8.6" carriers are the carrier bearings. Anything but the carrier bearings (locker, gears etc..) can be swapped between each other..
    I've got a few pics I found online to help see the diffrence.
    Please notice the sizes of the inner diameter and outer diameter of the bearings.
    This pic is of the stock 8.5" axle with the stock bearings:
    Bearing part #LM501349 Race part #LM501314
    This pic is of the stock 8.625" axle with the stock bearings:
    Bearing part #LM603049 Race part #LM603012
    8.6 carrier assy in a 8.5 housing.
    Bearing part #LM102949 Race part #LM102911
    8.5 carrier assy in an 8.625 (ex: If you are using an open diff from an 8.5 to swap in a lockrite to your 8.6) The inner diameter of an 8.6 axle but the outer diameter of the 8.5 axle
    Bearing part# LM603049 Race part# LM603012
    -Derek
    www.GiffinsPerformance.com
    1989 GMC Sierra
    5.3 Swap, Z06 Cam, Z06 Valve Springs, NX Express 150 shot, Giffin Performance Custom Front mount turbo kit, MPT70 Turbo, HP Tuners, Meth Injection, 4L80E with transbrake, 3" exhaust, 3.08 gears
    Turbo Build Video
    Good info.
