Results 1 to 7 of 7
Thread: asp alt pulley
    Mar 2006
    pearsall texas
    truck charging voltage too low truck did not want to start can i keep factory pulley
    00 silverado 5.3, 2005 caddy clip,mods asp pulley,e-fans,3.73s,custom intake,jba shorties,hypertech=14.9@95
    Apr 2003
    Allen, Tx(DFW)
    What is the size of the alternator pulley you have?
    02 Silverado
    02 TrailBlazer
    Mar 2006
    pearsall texas
    <div class='quotetop'>QUOTE(twobit &#064; Mar 20 2006, 01&#58;47 PM) [snapback]47517[/snapback]</div>
    it is about half an inch bigger than stock
    Aug 2005
    Spring, Texas
    Get the smaller alternator pulley if you want voltage, if you want power you need to go with the bigger alternator pulley, I just put the small one on my truck along with the Underdrive Pulley and it gave me a voltage boost. It has worked great and it is only like &#036;25 from summit racing. the bigger pulley will take more RPM&#39;s to charge your alternator, so if your idling you might have to REV your truck to keep it alive.
    Good Luck
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    Jan 2006
    San Antonio
    <div class='quotetop'>QUOTE(bulldog5.3 &#064; Mar 20 2006, 01&#58;52 PM) [snapback]47519[/snapback]</div>
    Get the smaller alternator pulley if you want voltage, if you want power you need to go with the bigger alternator pulley, I just put the small one on my truck along with the Underdrive Pulley and it gave me a voltage boost. It has worked great and it is only like &#036;25 from summit racing. the bigger on will take more RPM&#39;s to charge your alternator so if your idling you might have to REV your truck to keep it alive.
    Good Luck
    I second that.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Jan 2006
    Hell yeah&#33;&#33;&#33;&#33; Overdrive that alt. pulley&#33;&#33; LOL&#33;
    02 SCSB Z71:E-fans/nelson harness,ASP crank & alt,Volant ramair/k&n,UPD lid,Mac perf tube & elbow,Por & pol bbk 80mm TB/bypass,Meziere elec H2O pump,48# injectors,160 stat,LS6 intake,224/228,.581/.588,110šsep.,Dart 205&#39;s,Supermaxx header system,Corsa Sport,MSD 8.5 & coils, NGK #6(indexed), Built 60E,Fuddle 3400/cooler,custom alum ds/billet trans & pinion yolks,Weld chyenne 6D&#39;s, BFG kdw&#39;s, Nelson SD tune.
    Jan 2005
    Humble/Houston TX
    <div class='quotetop'>QUOTE(chevrolade &#064; Mar 20 2006, 01&#58;32 PM) [snapback]47513[/snapback]</div>
    its defective....ship the pulley my way and ill ship you a rollpan for your truck back
    old mod list: H/C/I/N/E/G 408
