Results 1 to 6 of 6
Thread: clearance between a/c lines and exhaust manifold
    North Georgia
    The main holdup on getting this going is a/c lines. There will not be room to put them on after the motor is bolted up. I have found a way but the lines are very close to the manifold. How much room do I have to have?
    The Corvette inspired Silverado is now rolling strong!
    http://www.ls1truck.com/forums/lsx-t...silverado.html
    Nov 2005
    ohio
    could you use some sort of heat sleeving to insulate them?
    07 SILVERADO CLASSIC 2500 HD 4x4 CREW CAB LT3 DURAMAX LBZ/ALLISON 6 SPEED 5'' MBRP Turbo back exhaust 6'' TIP /NO CAT- NO MUFF/ AFE Intake/ EDGE HOT JUICE /MERCHANT AUTO STG III Built Allison/P I ConverterTTS Twin Lift Pumps. Tierod sleeves/Cognito braces.17x9 Moto metals_______ Old Truck ,04 Z-71/Turbocharged,/cam/stall/Zippy Built TRANS/Nelson Tuned------
    North Georgia
    I plan on that. picture something like you use on a header. still need to know how much clearance is required. Its going to be very tight.
    North Georgia
    does anyone out there have a/c lines half an inch or closer to the exhaust manifold?
    May 2004
    86 Silverado LS1, I have a modified LS1 A/C bracket that I machined all of the bolting faces (both sides) off 1/8". It would move your compressor 1/4" away from the frame and closer to the engine and 1/8" closer to the inside of the bracket. Would this help you out or make things worse? It was a pain in the butt to machine and then I didn't like the way the F-Body compressor looked so I installed a truck compressor so the lines would come out the side. I'm not sure if I'm gonna keep it for anything or not at this point.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    North Georgia
    I dont know. My problem is the compressor is too far back. Your bracket might help. Ill look at mine and see. As far as the truck compressor...Im confused! I went and got a truck setup and it sat about a half inch forward more than the LS1 unit. The belt wouldnt work. I think the truck balancer/acessories are longer (farther forward)
    than the LS1. No room to move back. Is there something I am not seeing here?Thanks,Ryan cell # 770 652 9267
    EDIT....NITROUS, give me a call. We might be on to something here. I saw one of your pics on a post about headers. If that is the setup that will work with the belt, it will solve my problem (at least I think it will ). I would also like your take 1BADC10. My cell # is up top or my toll free is 888-846-8468
