Results 1 to 8 of 8
Thread: Cleaning the LS1...what works
    North Georgia
    Some of the motors I see on here look as good if not better than new. Since mine is going to be a daily driver I dont want to go the polished show car route. But, I like that clean, new look. What are the tricks to cleaning the aluminum. What about all the brackets and accessories.
    The Corvette inspired Silverado is now rolling strong!
    http://www.ls1truck.com/forums/lsx-t...silverado.html
    Jul 2005
    Galesburg Il
    I spray mine off at the car wash with the high pressure spayer. If it's really dirty I'd think that on a cool engine carb cleaner would clean anything. Brake cleaner might be safer. Or spray with a mulitpurpose cleaner like Simple Green and then high pressure wash/rinse. Then just take your time and do some cleaning with a rag. See mine at www.msnusers.com/jimsdogtruckphotos
    2002 white Silverado ext cab. Taillights filled, roll pan w/93 Cad lights horizontally placed, tailgate handle inside, Gaylord tonneau, bed slide & bed rug, all trim removed, Escalade door handles, 18" Enkei & Falcons, Speed grill. Grill shell, bumper pad, & valance painted white. Mirrors painted white. Many interior pcs painted black (over beige), black leather seat inserts and sun visors. 2" dropped DJM lower control arm, shackles/hangers for 4" rear drop. Engine: 5.3 , Radix w 2.8" pulley, 90 mm throttle body, Dart 225 heads, Comp Cam 581-588 224-230 on 114. ARP head bolts. KTech rod bolts. Alky Control methanol injection, Pacesetter lt's into elec cutouts then 4" polished Magnaflow SS mufflers then 4" ovalized SS pipes exiting in front of rear wheels both sides, gas tank removed and 24 gal. fuel cell where spare tire was w/Aeromotive pump, pre and post filters and pump controller & -10 SS fuel line. 160 thermostat MSD wires & Perma Cool fan, 34" radiator, Meziere elec water pump. Valve covers, alternator & brackets powdercoated white. Built 4l60e, 4.56 with Detroit Locker Trutrack. 2 Interceptor logging guages, FAST dual 02 sensor wb gauge, Cyberdyne vac/boost gauge. Truck is actually the property of a little Benji type dog. Pics of him and the truck too www.swardphotos.shutterfly.com
    Oct 2005
    Houston, Tx
    make sure you cover your necessary stuff though. i did that one time to the car i had. and water got into the plug wires and messed it up . i jus had to replace the wires. it was clean but ran like crap.
    Golden rule is, if you won't use it to clean your polished aluminum wheels, don't attempt to use it to clean your engine. Cleaners with ammonia in them will acid etch the aluminum.
    Jan 2006
    San Antonio
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jan 18 2006, 09&#58;42 AM) [snapback]41365[/snapback]</div>
    Golden rule is, if you won&#39;t use it to clean your polished aluminum wheels, don&#39;t attempt to use it to clean your engine. Cleaners with ammonia in them will acid etch the aluminum.
    I was going to say the same thing.
    Tattoos, Kustoms, Chops, Guns and Pits..........Need I say more? AFTERLIFE KUSTOMS.
    Getting ready to put an 82 Chevy 1/2 ton blazer under the knife.
    EL JEFE
    ROUGHNECK
    Nov 2005
    Buy some good engine detail and shine. I use it on our cars when we do shows. Whip down all your plastic and rubber parts with it, they will look new and shinny for a long time.
    SOON TO COME!!!!
    Oct 2005
    Baton Rouge, LA
    I&#39;ve always gone to the car wash to spray their "engine cleaner" on & rinse off. I try not to drown the engine when rinsing off, but you&#39;re safe as long as it&#39;s running and the alt stays clear of direct spray. Nowadays, I do this in my driveway (since I just bought a house... woohoo&#33 with zip wax & water, and it&#39;s just as good. I took my Yukon (&#39;02) to the dealer for an alt swap, and the tech in back said that&#39;s got to be the cleanest engine bay he&#39;s worked on.
    Jun 2005
    Cumming, GA
    Now, normally, my engine is spotless, but it rained hard here last week, and I went around a curve in the road into a giant mud puddle. When I got out, I looked at the body, and there was no mud anywhere, so I thought I got off easy. Earlier this week, I popped the hood and there was dry mud (Georgia Red Clay) all over my precious engine bay. Does anyone know of somthing that will take that off, or am I just gonna have to get after it with a toothbrush?
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
