Results 1 to 2 of 2
Thread: 4L80 swap problems
    4L80 swap problems
    I repowered my 2005 suburban with a built up 6.0L and installed a 4L80e. Reused the harness an Neutral Switch as well. Once everything installed I fired the unit up no problem. I purchased a tune from “Mail order Tune” to get me started and when I installed the new tune I am in a no crank situation. The tuner swears nothing in his tune would be the issue yet when I put my original tune back in, it will crank and start. Any advise of which direction to look would be greatly appreciated. If this is the wrong feed please direct me where to ask Please…
    I would also like to add when I use my HP scanner it shows the transmission in D2
