Snapped output shaft, rebuilt trans,code c0055! Please help
Well long story short , i snapped the output shaft in half, had the transmission rebuilt by a reputable shop (bench job) and i removed/installed myself. Installed a Hardened output shaft .
have it all back together and of course abs and brake light came on and no 1-2 shifting and no speedometer.pulled codes said front left wheel speed sensor ,and rear wheel speed sensor.
replaced ,both sensors ,cleared codes , abs and brake came back on,checked codes and now its only showing c0055 rear wheel speed sensor curcuit malfunction. i replaced the sensor again but no go and speedometer is always dead.
i have checked grounds and all seam fine. Could i have shorted my PCM? any test suggestions are appreciated .
Truck is 06 silverado 1500 2wd crew cab 4.8 Thank in advance guys
06 silverado crew cab 4.8L
STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
Nelson custom tune
built 4L60E-hopefully it lasts
2500 stall-Hughes converters
42LB injectors
3.5 Magnaflow exhuast
6inch lift on 35x12.50s
