Results 1 to 10 of 16
Thread: 2007 4.8 to 2008 4.8
    May 2015
    bought a 2007 silverado 2wd 4.8 with 15,000 miles to install in my 2008 silverado 4wd which came with 4.8. Changed oil pan and motor mounts. Crankshaft sensor on 2008 is on front and 2007 is on back. Re-routed wire to back. Truck will not start. Will it need to be re-programed
    Nov 2013
    Fort Hood, TX (for now)
    Do both engines have AFM/VVT? Check and double check all your connections, specifically your grounds.
    The 07/08 are wired the same. So that is fine. ECM wise.
    All the gen3 and gen 4 engines have the crank sensor behind the starter, towards the back.
    All gen4 engines have the cam sensor in the front. On the timing cover.
    We need more info.
    May 2015
    The original motor has the cam sensor on the timing cover... The 07 has a cam sensor in the back around the oil pressure sensor. Is there any way around that?
    Look at my post above regarding crank sensors. Sounds like a reluctor wheel issue.
    Meaning gen3 vs gen4
    If the engine is newer than the truck. Meaning is the engine a gen4. Then u need a lingenfelter box
    May 2015
    So far I have replaced the crank sensor behind the starter with the original because the actual plug was different. Also I rewired the cam sensor to the rear. The supposed 07 has the knock sensors under the valley pan where as the original 08 has them on the lower block. I changed them out also. I know those wont not let it start but those are some of the differences. Would the reluctor wheel need to be replaced? Or do I need to replace the camshaft gear because those have different patterns for the sensor to read
    Another fyi. 4.8 didn't have vvt or afm in 07/08
    So it sounds like u forgot about the Crank sensor wire that is on the truck harness and accidentally rerouted the cam sensor to the back. Maybe?
    Truck won't start without a crank signal. That's where it all starts.
    Find the crank sensor connector on the trucks harness and plug it in behind the starter.
    Find the cam sensor connector on the trucks harness and plug it in the timing cover.
    Both those engines should be the same so wiring won't change.
    If one of those engines have afm it's a 5.3
    May 2007
    Oak Forest, Illinois
    Wouldn't the 2007 have a 24x crank reluctor and the 2008 have a 58x crank reluctor?
    Jeff
    I'm thinking it's a 07 Classic, so Gen3. Maybe
    regardless of engine generation, crank sensor will always be in the back, behind starter.
    He mentioned re-routed, so that might be the cam sensor he re-routed.
    look at the crank sensor, black is gen3, grey is gen4
    we just need more info
