Thread: 01 RCSB 5.3 swap 4l80 swap questions
    Feb 2013
    MO
    I have a 01 Rcsb nbs that originally was a 4.3. I swapped in a 5.3 a while back and now am looking to upgrade to a 4l80. I found a good 4l80 out of a 99 obs but I havent found any info on whether or not it will swap in. What year 4l80 do you look for? I know I will need harness mod, crossmemeber mod, etc I just need to know what year 4l80 are the same, What years are different. Thanks
    Feb 2013
    Mexico Missouri
    That thing make enough power to need an 80 lol Id go for a locker and gears 1st
    Nov 2011
    New Brunswick, Canada
    the 99 trans will work. i've got a 97
    Mar 2013
    Long Beach California
    Quote Originally Posted by fabunlimited View Post
    yeah, im not sure the time/cost is worth it for the 80. especially if your current trans is fine. unless you start modding that 5.3 i dont think an 80 is neccesarry. but if you still want to, i know the later models are better. i forget which years they made the changes but the big issue they changed was the inlet line from up front to several inches back and up in order to lubricate some bearing. you can tell by looking at the location of the outlet line.
    CALI LEGAL ENGINE SWAP!
