Results 1 to 10 of 12
Thread: Walledition-New Project: Boost/Turbo-Fuel/Return System, Build
    Apr 2014
    Hey guys! Ive been on this site for a time but havnt post before, iŽll do my best to make this detailed and interesting even its a small project compared to what a lot of you guys have going on with your trucks. Please feel free to comment, advice and feedback
    Project consist of:
    2005 rcsb stepside 6.0 LQ4, 4L80E with TransgoHD2, TR224 112, 14bolt/posi/4.10`s, Circle D MultiDisk 4C 3600-3800
    This is not my daily driver but i wana be able to drive it on weekends and have a consistent bracket truck for small local racing events.
    Upgrades:
    PT7475
    KBracing T4 Hotside
    Custom Exhaust
    Custom Coldside
    Jgs 40mm wastegate
    Rps 50mm blow off valve
    Truck style 80lb/hr@4bar injectors + ev6 to mini delphi
    Converting to return system (fuel)
    I will go into details as i move on with this project:cheers:[/QUOTE]
    Apr 2014
    Hot Side:
    Time to pull the headers/exhaust/intake out and start installing new uprades
    I used 1" Cool It Thermo Tec black wrap on the turbo manifold and coated it with Cool It Thermo Tec after wrapping it, supposed to last longer and the coating looks good on any metal, in my experience the zip ties sucked big time since the system they have to ajust them doesnt let u make a tight fit so i went ahead and got regular hose clamps and just coated them after installing them for a cleaner look
    Stock driver side manifold sand blasted and coated with 2000f as well
    Crossover pipe was bolted on, spot welded and fully welded after, i used 2" Cool It Thermo Tec black wrap and coated it as well
    Permatex 81878 Ultra Copper High-Temp RTV Silicone Gasket Maker was used to seal the driver side manifold and crossover pipe
    wastegate installed after crossover pipe was done
    Apr 2014
    Intercooler mount:
    I had a hard time trying to find info on mounting a intercooler behind the grill and rout the 3" piping on the sides with a 04+ 34" radiator, thanks too "smokeshow" he gave me some tips, it can be done keeping the pcm and battery on stock location and YES its tight
    Little welder wish made it happend lol
    Passenger side:
    To make room for the 3" pipe i had to take the ac gas out, weld a small extencion in and refill the ac again
    Intercooler Piping:
    Welding: (First i tried mig welding, later had everything rewelded with a tig welder, looks much cleaner)
    Mig Welding
    Vs. Tig Welding
    Apr 2014
    Cold side and ic bracket done (had it powdercoated black):
    Apr 2014
    Oil feed and return ports:
    Feed i taped in this fitting:
    Return:
    Apr 2014
    Since i was dealing with powdercoating i had some more parts sandblasted and powdercoated to clean the engine bay
    Mar 2013
    Edmonton, AB, Canada
    Looks really clean! I just have one concern; Where you mounted the wastegate isn't ideal. The wastegate won't be nearly as efficient if it were placed downstream of both manifolds.
    Apr 2014
    Quote Originally Posted by shmiet View Post
    Thank you
    Im not saying its the best place for a high hp combo but its a proven to work kit from kbracing, ive been using it for months now and so far im very happy with the way it works, there are actually a couple of 1000+hp setups around with that kit
