Thread: brake light switch wiring
    Dec 2014
    how does everyone wire there brake light switch wires for the 5.3l computer.
    its one of the things im stuck on i see alot of build where they are buying a new brake light switch out of like a Monte carlo most of these projects are older vehicles though so its throwing me off
    99 tahoe 4x4 stock gauges
    01 5.3l with the 4l60e and np246 witch painless wiring harness
    I was told to just wire it into the old signal from the old harness.
    What im trying to figure out is on the the wiring diagram I have it shows the signal as a purple wire. On my new harness I have 2 wires saying it's for the brake light switch a purple and a pink wire
    Jul 2010
    Douglasville Ga
    You are using an aftermarket powertrain wire harness in a 99 Tahoe? Why?
    My guess is that the pink wire from the Painless harness is a feed circuit. Since your vehicle already has a factory brake switch and feed circuit, the pink wire will be unused.
    Sep 2009
    NE Ohio
    Maybe this will help
    http://imgur.com/O59mIml
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
