Thread: 71 Cheyenne ZZ502 in Seattle
    Jul 2005
    Truck was purchased in Seattle approx two and half years ago with about 130k original miles on it with the original 350/T350/12 bolt/3.08-disk/drums. I then spent two years converting it to a modified ZZ502.
    Details on the motor-
    ZZ502 502hp plus
    Complete tear down to include new file fit rings (to fix oil consumption)
    Milled heads for a 10-1 CR
    Ported Intake and valve job
    hvy duty manley pushrods
    Crane Solid Roller Cam 615/636-296/304 adv dur
    Crane Gold Roller Rockers
    Crane Valve Springs
    Edelbrock Victor JR manifold
    Barry Grant Speed Demon 850
    HEI Upgrade
    This combo was dynoed prior to shipment and made 580 flt/lb's of torque from 2900rpm (633ft/lbs max) and 663hp@ 6100 rpm. This is a pump gas truck
    Since then-
    $2000 in a T400 swap to include shortened driveline
    Swapped carbs to a Mighty Demon 850 with mech secondaries
    Added a CS144 140 amp alternator
    Added new front shocks
    Used all OEM BBC pulleys, accessories and motor mounts for the motor swap
    Holley Blue electric Fuel Pump
    New Brake Booster
    New Cermachrome coated Hedman Headers
    Full 3 inch mandrel bent exhaust with H pipe and 2 chamber flows
    BBC "Chevrolet" Aluminum Race Valve Covers, drilled and welded for baffles and PCV
    Complete BeCool Module-Radiator, can and fans
    New Dash pad
    New Carpet
    New Rear Bumper
    Added Sun tach with shift light
    Added earthquake amp to existing CD head unit and 6-1/2" Rockford Fosgates
    I purchased the truck originally for about $5k
    I have spent over $14K on the motor swap alone
    The truck itself is in very good condition and is a looker. The cab and sheetmetal is very clean. Only minor things to be perfect. I have all the original powertrain parts. The truck has less than 1000 miles since swap. It is solid, it isn't quiet, and it goes.
    Asking $14,000.
    Mike Turner
    01 8.1 Burb
    http://www.speakeasy.org/~tracer/LOG...uz%20small.jpg
    Perfection's in the Vision...
    PH: 425-427-6690
    Bringing innovative, affordable accessories to the automotive world…
    www.focuztech.com
    Very nice.
    May 2004
    Man that's saweeet, I love those old '69-'73 body style GM trucks !!! It's clean w/ the show and has the go to boot...F@#%in' awesome...
    13.920 @ 98.94mph...[/b]
    Jun 2005
    South Florida
    beautiful truck!
    http://denial.clanned.net/truck/stsig.jpg
    2001 GMC Sierra 1500 Sportside: Project esoteric
