Hi,
Does anyone know of a coolant temperature sending unit adapter that will make the 1988 K5 Blazer sending unit fit a 2008 LMG 5.3? I know drilling is one option, but I'm thinking there is probably an adapter out there on the market.
Thanks!
Hi,
Thanks!
http://lmgtfy.com/?q=ls1+temp+sensor+adaptor
hahah jk man. i like using that.
autometer also has one for the oil pressure sender. Allows the metric hole to be converted to something we're used to.
I think summitracing has the cheapest price.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
CALI LEGAL ENGINE SWAP!
might be a little late, but i used this harness adaptor, you can wire it to your old gauge and hook it up to the LS harness. hope it helps
http://www.nookandtranny.com/mm5/mer...Category_Code=
No adapters required.
Add one extra wire from the LS temp sensor location, connected to the OE dash gauge, and install the 3 wire sensor and pigtail for a 1998 V8 Camaro. The cost is about $30 for the set, and it replaces the stock LS temp sensor in the cylinder head.
Installation is a snap. Two wires connect exactly as the original LS sensor, and are positioned the same in the connector. They feed the ECM a 5v loop. A third pin is for the dash gauge. It is the usual variable resistance to ground, through the sensor body.
The part numbers are:
Sensor- 12551708, tx111, or tu280
Pigtail- pt2319, s619, or 1p1065
