Originally Posted by
farmtruc
Performance parts compliment each other; so if you do one thing it typically leads to another.
IMO, if you're replacing lifters, just replace them and be done with the engine. Lifters being replaced aren't directly related to installing a performance cam.
You'll need to tear the frontend down.
If you do just lifters , then you'll be done and back on the road the same day.
I'd use stock head gaskets and manifold gaskets, FullService stock replacement head bolts and be done.
Now if you're looking for power, get a cam that doesn't require a larger stall converter.
headers also compliment a cam.
Might wanna do the cai as well.
