Results 1 to 10 of 21
Thread: Need block suggestions! Having issues
    Edmonton, AB, Canada
    Engine specs as of last build:
    -Thompson Motorsports 5.7l (Refurbished seasoned 5.3l)
    -72mm Magnum turbo
    -TU1 Custom Grind cam(spec speed.inc)
    -799 heads
    -GM MLS head gaskets
    -ARP head bolts
    -.660" Trick Flow dual valve springs
    -Titanium retainers & locks
    -7.400" Comp Cams Chromoly Push Rods
    -LS7 lifters
    -5.3l(LM7) rockers
    -Forged Probe Pistons 3.902" flat top
    -TMS Moly rings
    -4340 Forged scat I-beam connecting rod w/ ARP 8740 rod bolts
    -King racing bearings
    -Melling high pressure relief oil pump
    -TR6 spark plugs
    -"Muscle Car" oil pan
    -All other parts are stk 5.3l(LM7)
    So here's the story:
    Block #1: 5.3l out of a 120,000km 2001 Silverado
    Get on the dyno and after several weak pulls it starts venting bad. Pull the head Cylinder number 5 had a broken piston. After further inspection multiple pistons had cracks between the ring slots.
    Block #2:Thompson Motorsports 5.7l(bored from 5.3l) engine(The one described at the top of this post)
    Runs for about 15min while on the highway. I started accelerating going 130kmh with 5lb of boost. Engine locks up and wont turn over. Pull the block out- 3 cylinders cracked to the waterjacket, pistons are wedged in cylinder bore, and most of the rods are bent.(no damage on the gaskets or the head really, although the heads show signs of detonation.
    Block #3: Get warranty Thompson Motorsports 5.7l(bored from 5.3l) engine back
    Tried installing cam but it was very tight. Turns out the cam was bent from the last engine blowing up. Decide to get the whole thing gone through. Fix the cam, but the sonic test determines that the cylinder walls in some spots are .140". After doing some research a lot of people say it's ok for NA but not for boost(i plan on going up to 18lb).
    Additional info: Most parts have been reused several times now. I have used new head gaskets every time and got new head bolts as well.
    So: I have the first block still with some scoring in the cylinders and a freshly sandblasted lq4. What do you guys recommend I do? I am willing to buy a different block if need be, but if either of these could be used I would like to go that route.
    Any help would be greatly appreciated!
    I can post pictures if need be
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
    Dec 2008
    South Carolina
    what caused the first tms engine to lock up? im dealing with thompson right now and having some issues myslelf...
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
    What I am thinking is that the walls were too thin to begin with and with the light boost it split. They said they had no idea why it would break that bad but the only thing I can come up with is really thin walls. My engine builder wants me to go to a 4.8 just for the wall thickness to get a bulletproof setup. Ive already spent about $16000 on this project and I'm pretty sick of it. I am glad Thompson gave me a warrantied engine but when I sent it back they kept my head dowels($22 in Canada for 4) and they didnt clean out my oil pump or give me a new one. I pulled it apart myself to get the particulate out. Im really not too pleased
    And to top it off I'm stuck with a $3500 short block that I cant boost
    Dec 2008
    South Carolina
    yea that sucks. The 5.3 and 4.8 use the same block. The 3.902" is the pushing it on the 5.3 block imo. Iv always ran a 3.89" (factory ls1 bore size) bore when i punch out a 5.3 block and never had any problems
    Hmm, so do you think I should do the iron 6l or bore out my scored 5.3 to 3.89"?
    Dec 2008
    South Carolina
    Do you already have an iron 6.0?
    Quote Originally Posted by shmiet View Post
    Your engine builder doesn't know the 4.8 blocks are the same as the 5.3... not much of an engine builder.
    you skimped on pistons, you skimped on the block... what do you expect?
    I miss interpreted what he said, he meant they can handle boost better than the 5.3 due to the stroke.
    I expect failure, cause I'm dumb eh.
