Got a 5.3 in my 74 chevy truck. I need to know what to use for a throttle cable. Motor is out of a 99 silverado. Also what lower rad hose can i use? Am gonna be use a stock replacement sbc radiator. Thanks for any input
anybody?
I don't see why one from a NBS truck wouldn't work work just fine. You may have to work on the hole where it passes through the firewall just a little but that should be easy enough.
97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
TURBO IN THE WORKS
Same should probley go for the rad hose as long as its ports are bottom on passenger and top driver side
Not to sure on your 1974 truck but on my 1992 I used the 1999 throttle cable. I just had to shape the hole going through the fire wall so cable would fit.
im gonna try using the 99 truck cable...I guess both the 5.3 and sbc hose could work so im using the sbc hose since its cheaper
