Results 1 to 10 of 17
Thread: planning ls swap f150
    Mar 2014
    In starting the planning process on converting a 95 swb f150 to a 4.8/5.3 4l60e instead of the tired old inline six and junk 5spd that are there any info on where to look and research will be helpfully and appreciated some of my questions include
    can I use all aftermarket gauges
    Should I be able to remove the factory ecu or will it be needed for lights wipers and the such
    Any help will be much aprreciated
    Yes, all aftermarket gauges will work. They usually are supplied with the sensor/sender as well.
    Def removed the factory ecu, it won't be needed and less mess.
    here's one.
    http://www.ls1truck.com/newstorage/pics/codytat/
    Feb 2012
    think I just threw up in my mouth. But I guess if you want that ford to run fast give it a chevy motor
    Mar 2013
    Long Beach California
    this sites name is LS1Truck.com Not LS1GeneralMotorsOnlyTruck.com ANY LS motor in ANY Truck is allowed on this site in my book. I say do the swap, race a lightning and let him wonder how you got your f150 moving that fast on a "ford" motor!!
    CALI LEGAL ENGINE SWAP!
    Aug 2011
    Ellsworth Air Force Base, SD
    ^Put an LS in anything, my neighbor has been watching my conversion and has decided to do his Ford Bronco with a 5.3. Go for it, you will definetly be happy with the end result.
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
    above f150 getting faster, forged sixo going in and a th400 as i type. i'll post up pics.
    it'll be a while before it moves on its own power, truck leaving getting the back half done.
    Nov 2006
    Perris, CALIFORNIA
    Any updates? Im hesitating on my 1995 f150.
    no updates really, the forged sixo is in and the truck is running.
