Results 1 to 5 of 5
Thread: switch 12v were to tap?
    Jan 2014
    I'm getting down to the final stage of my swap, I have my harness thined out and lengthened/ shortened. So this leads my to the fuse block and relays. I'm going with the lt1 swap setup.
    He only has 5 pink wires ran to the block, I have 13 or 15 (can't remember ATM) to run for switched 12v. how did he come up with only 5? Did he splice a few together up the harness to make 5 main groups to run to the block? If so how many can be spliced together with out over powering the main spliced wire between the block and slice?
    Also were should I tap for switched power to the fuse block relay.
    Thanks guys.
    Aug 2011
    Ellsworth Air Force Base, SD
    This is from Brendan's step by step harness rework pictures on how he does this part of the wiring.
    As far as switched, I just used my large pink wire coming out the factory C100 connector on the driver's side firewall.
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
    Jan 2014
    Iv been digging through his web site for months now and havent seen that pic yet. He has so much info on there its unreal. What section/link or "area" did you find that?
    Thanks
    Jan 2014
    I found it. Thanks man. Made my tomorrow that much easier!
    Oct 2013
    Jacksonville, AR
    You can also check his Facebook page where it shows you how he tapped into the 88-94 fuseblock....
