Results 1 to 9 of 9
Thread: Help!! Clutch pedal hard as a rock on ls1 c1500 5 speed
    So I was bleeding my clutch today and when I was. pumping the pedal it got stiff. I told my friend to bleed it and it got soft but as soon as he tightened the nut and I started to pump it, it got stiff as a rock again. What could it be? Slave cylinder is new, would i need to shim it? Feels like the slave is long thanks!
    Jan 2014
    What clutch do you have?
    Quote Originally Posted by LOWnEASY View Post
    Zooms performance clutch. It has part#1377c throwout bearing.
    And it has a 4.8 flywheel.
    Jan 2014
    Is it so stiff you can't push it in or just really firm?
    Sep 2010
    N FL
    Make sure the connections are pushed in tight and locked! If the line to the slave is not snapped in good to the slave it will be hard like u explained! Good luck!
    Quote Originally Posted by 1BAD6660 View Post
    Ill take a look thanks!
    I cant push it in more than halfway it just gets really hard its like something is in the way.
    Got the clutch working again guys. The rod was actually under the fork thats why it would be hard as a rock...i put the slave rod on the fork and it works great, thanks for the help!!
