Results 1 to 8 of 8
Thread: 88-95 obs return less fuel system parts (i need help)
    Jan 2014
    What all is needed for 4.8/5.3 return style fuel system in a 88-95 obs Chevy I don't mind if its a little extra work, but I'm having to pinch pennies here, as I only have 80-90% of the funds as it is depending on the price I can find my motor at. any and all help is appreciated. Thank you guys.
    Edit: made some typos, want to run return style system and not the vett filter.
    Jan 2014
    The TBI motor already has a return line, so would these two fittings all I need besides a pump
    Rus-644110 and rus-644120
    Long Beach California
    this question has been answered numerous times on this site. in fact, its in the 2nd post in the STICKY.... i suggest you read through it. it answers both of your questions and many more you will have.
    http://www.ls1truck.com/forums/showt...4782#post74782
    http://www.ls1truck.com/forums/showt...046#post520046
    Jan 2014
    I'm sorry, I meant use the return line. Not return less. I don't want to go with the vett filter.
    It seems a cheaper rout to only buy two fittings and use the stock filter and lines.
    Editing first post.
    Jan 2014
    Think I found what is was looking for. And for any one els have the same question, here's a link
    http://www.fullsizechevy.com/forum/g...-obs-95-a.html
    Jan 2012
    warwick ny
    If you don't use the corvette filter you will need a regulator to get the proper psi.
