Results 1 to 8 of 8
Thread: L33 block decking
    Feb 2013
    L33 block decking
    Taking my block to the machine shop next weekend and need to know how much I can shave off. I have searched all over the web and can't find any info. I would like to raise the cp a little bit and I came up with 10.34 :1 if I get .020 taken off. I just want to make sure It will not mess up the block by taking to much off. Thanks.
    Apr 2006
    Bellevue, Nebraska
    .05 from block=1cc
    .07 from head =1cc
    Search intrawebz for compression ratio calculator. Not static and dynamic. Read up on both the decide where you want it.
    Feb 2013
    Ok thanks. Ya I've already decided to deck the block I just didn't know how much I could take off without rendering the block useless lol. I have a book on rebuilding ls motors but it is not specific on this subject. .020 would get me where I want to be.
    you need to talk to a engine designer and or builder, if you mention what youre wanting to achieve they'll asist you! theres other ways of accomplishing compression without milling the deck.
    Simple: 408 on steroids!
    single digits coming soon!
    Round Rock, TX
    I would deck the heads before touching the block. A stock l33 piston is gunna stick out of the hole around 0.006. If you knock off 0.020 that only leaves you with .0.025 between the piston and head with a 0.051 gasket.
    Feb 2013
    Ya maybe I went to the wrong machine shop but he told me to research if it was possible or not. Lol he hasn't seen the block yet to measure. If I did the heads .020 off would that cuase intske alignment issues or valve clearance issues? I read where somebody did that much on a ls6 but I think the ls6 has dished pistons.
