Results 1 to 10 of 17
Thread: Knocking Sound!!
    Oct 2012
    San Antonio, Tx
    Knocking Sound!!
    So my 5.3 has a knocking sound, could it be the cam, lifters and push rods? Any local shops in SA that wont charge an arm and a leg to get this fixed? The seller is giving me the run around and i just want to get my 84 on the road!
    http://www.youtube.com/watch?v=7XmhZANIFug
    Jan 2007
    Stafford, VA
    Can you get a stethoscope to pinpoint where the knock is coming from (you can get one from Harbor Freight for cheap)? If not, maybe a long handled screwdriver?
    - Paul J.
    2006 Silverado LT3 L33 Z71 - Mods: K&N Air Filter; Taylor Wires
    2008 Azera Limited - Mods: (Yah, wife's car ... not happening)
    (SOLD) 1994 Camaro Z28 - Mods: (Too many to mention)
    (SOLD) 2004 Suburban 5.3L Z71 - Mods: Flex-a-Lite 292 Monster Fan
    (SOLD) 2000 Silverado 5.3L Z71 - Mods: (NTIKO)
    (SOLD) 1991 Suburban 350 2WD - Mods: (NTIKO)
    Oct 2012
    San Antonio, Tx
    I guess that will be my next purchase. I also took the valve covers of and the one on the driver side had marks from the rockers. Those sections weren't really stained by the oil.
    Dec 2008
    san antonio TX
    sounds like a lifter problem to me!!
    Ponca City
    That fan looks safe
    Slowest in Oklahoma...
    wichita falls, tx
    My bet is on a lifter.
    White Settlement, Texas
    I think that you would only be hiding the problem from yourself for a little while by putting the equivalent of oily molasses into your engine, that stuff isn't a fix for the problem it's a cover up kinda like putting red tape on a busted out taillight
    Jan 2012
    warwick ny
    You said the rockers are hitting the valve covers. Are they aftermarket? That could be your sound. Check and make sure they are tight. Rockers shouldn't be touching the valve cover.
    Oct 2012
    San Antonio, Tx
    No, its the stock covers. I removed the covers one at a time and checked the rods and tightened the rockers back to 22. When I started the truck with either cover off you couldn't hear the knocking. Seems likes its echoing off the covers.
    Quote Originally Posted by gagliano7 View Post
    Quote Originally Posted by coyotes33 View Post
    When you say tightened back....were the rockers loose? If so I would be willing to bet that was your problem.
