Results 1 to 7 of 7
Thread: oil drain timing cover
    looking for info/pics of where you guys are putting the turbo drain, i know alot of guys go into oil pan, but being as tho i have the timing cover off for cam swap, and i know guys do run the drain into the timing cover, looking for pics of best location.
    Ponca City
    Slowest in Oklahoma...
    Pittsburgh, PA
    oh shit son...what do my eyes spy
    Quote Originally Posted by ecld_07 View Post
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    any pics of guys running drain into timing cover?
    Yes sir - just finished mine. Although I can't say I recommend it. I had someone help me weld in the -10AN fitting on the cover. Drilled a hole in the cover where one of the factory indents are. Those are for the oil pump mounting bolt heads by the way -so your fitting cannot be a threaded type with an O ring. Won't work... I used an Earls 90 swivel and ground it down pretty thin to clear the balancer. Also had to cut a few threads off the Earls fitting so it can be removed without pulling the balancer. Huge friggin hassle to remove and install that thing by the way... Then I used Summit push lok 90 barbed fitting hose up to the turbo. Since it's only drain and no pressure, shouldn't be a problem with the fitting being on the thin side. I've had mine up and running fine now and no leaks. I didn't want to go the pan route either, but if you can I would certainly recommend it.
    Feb 2012
    Quote Originally Posted by George C View Post
    Stock crank pully LOL, but 2 lines......2 snails
    Ponca City
    Na. Easy fill oil system lol
