Results 1 to 10 of 13
Thread: LS swap in a 1999 Dodge Dakota R/T
    Aug 2012
    Tampa, FL
    The swap that has Mopar guys pissed.
    About a year ago, we ran across a 1999 Dakota R/T with bushing and ball joint problems, and picked it up from the auction for $2000. It turned out, it also had cracked heads, which is a common problem for the 5.9 Magnum engine. Initially, we intended to use a 408 block, new heads and a Kenne Bell blower to give this truck 400 or so HP.
    Out came the engine:
    Using a foam mock-up block and wood plates, we developed adapter plates to fit the LY6 engine into the engine bay:
    And the engine dropped in nicely
    The 6L90 transmission was located with a welded spacer:
    A 5 inch aluminum driveshaft and rear disc brake conversion completed the project
    And finally
    Aug 2012
    Tampa, FL
    Video of the LS motor going in:
    http://www.youtube.com/watch?v=D9RAO8TpLBY
    Apr 2011
    never seen a ls swap on these trucks nicely done
    2006 Silverado aka (Bad Bitch)
    K&N CAI, Diablo Predator, muffler delete, and a vette servo. 14.7x @ 93 mph (sold)
    1998 SS Camaro aka (Silver Bullet)
    LS6 intake, ported TB, LTs, ORY, cut out, and a pantie dropping tune by Nelson. 12.6 @ 110 mph 327 hp 347 tq
    2011 ecsb silverado aka (silver sleeper)
    forged 6.2 and a small snail
    Another dodge ram ls swap here maybe he will chime in!
    Jan 2012
    DFW, TEXAS
    excellent build,
    Feb 2011
    Fort Worth Texas
    Way to go, that's really stepping outside the box! Great job.
    Aug 2012
    Tampa, FL
    Thanks. Now I am looking at all of the extra space on the passenger side, and thinking maybe turbo? 650-700 hp should be attainable.
    [QUOTE=casias;505663]The swap that has Mopar guys pissed.
    Hey Scott it looks like you didn't even clearance the cross member and that's a stock pan!
