Results 1 to 9 of 9
Thread: injector help
    injector help
    can i use these? thoughts opinions?
    80 lb Short D5 High-Z Fuel Injector MT
    Item Code: FI114700
    Weight: 40.50GM
    Manufacturers : Siemens (Continental)
    Stock: Yes
    Categories: Fuel Injectors - High Impedance
    Manufacturer P/N: A2C32624700
    Coil Resistance Ohms: 12
    Spray Pattern: Cone
    Series: DEKA 5
    Connector Type: Minitimer (Bosch EV1 - Jetronic)
    O-ring Type: Viton
    E85 Compatible: Yes
    Weight (non-shipping): 29GM
    Test Pressure PSI/KPa: 43.5/300
    Test Solvent: Heptane
    What are your goals and what will they be used with? I think the simple answer should be yes.
    600whp.. possibly a bit more.. on 2001 stock intake...
    Gonna push 600 thru a stock truck intake? Should be fun. (not saying it can't be done) Should be plenty injector for the power level especially at higher fuel pressure. I am not sure about the connectors or length though.
    yeah the length is what im most concerned about connectors are no biggie
    S.A. Texas
    Stock intake is fine. Your pushing the air in anyways I would assume, the shorts should be fine too. its the car ones that are longer.
