Results 1 to 9 of 9
Thread: Short bed to long bed conversion?
    Jan 2012
    Guys I have a 99 silverado, it's a rclb. I have had this truck for a good while, it just broke 100k miles. I have replaced the brakes, tires, fuel pump, I have put a lot of time in it, it's a really nice southern truck, no rust whatsoever.
    I really don't want to sell, but I want a shortbed. How hard will it be to do a conversion? I have a lot of time in it, and it's paid for. Is it a crazy idea or is it possible?
    Thanks for all the help, tips, and advice.
    Mar 2011
    Amarillo TX
    I think after the time and money, you would be better off trading it for a short bed.
    2000 ECSB 5.3L with K&N CAI, true duals with flowmaster 40s, and 200k miles!
    Its possible. and Prolly not all that hard, look on performancetrucks.net its been done before.
    May 2010
    Galveston, Tx
    95 C1500 LM7, built 4L60e, Circle D 3200, LT's, Nelson tune, open differential, 3.42, and LS1 e-fans. Tractionless
    Broken Bow, OK
    I've known people to cut them, but honestly it is easier to get a frame and swap everything over. Maybe you will get lucky and get the tank and drive-shaft and some lines with the frame.
    I'd just buy a different truck though.
    Oct 2007
    Bandera, TX
    Depending on your welding/ fab skills it's not that hard. I've done it both ways. Either way you gotta shorten frame and driveline, but you can either cut your bed and re-weld it or find another short bed. The cool thing about cutting the bed you have is you can make it shorter than a standard short bed. You would be amazed how much diff a few inches makes.
    single digit street truck
    for build info
