Results 1 to 10 of 16
Thread: Help me pick 4.56 or 4.10's ???
    Aug 2010
    Cannon Falls Mn.
    Truck has 34.5 Tall Nitto's on it now and I will run BFG's mud terrains on black steel wheels in the winter.
    What gear should I go with? 4.56 or 4.10's? Truck still has the stock 3.73's in it now and it is a absolute dog down low.
    Thanks in advance.
    99 4x4 5.3 NELSON TUNED / 02 Ls1 CAM / 02 Ls1 "241 Heads" Port/Polish milled .045" / 03 INJECTORS / AIR RAID JR. INTAKE / PORTED THROTTLE BODY / TR55's / EGR DELETE / E FAN's / CAT DELETE / EXHAUST DUMPED
    Headers, Transgo HD2, 3200 stall, 4.56 gears coming soon.....
    May 2010
    Fort Wayne, IN
    4.56
    Arizona/Utah
    Quote Originally Posted by Mf2racer View Post
    4.56
    +1 it's a big boy truck. Let it eat.
    9" & 5.00s!!
    Oct 2007
    Bandera, TX
    i have 35s on my truck that i daily drive and 4.56 is perfect. The change to 4.10 from 3.73 would be hard to even notice.
    single digit street truck
    for build info
    Aug 2010
    Cannon Falls Mn.
    Do you have a stall, if so what size? Is there a need for a stall at all? I plan on going with like a vinci trucker cam or something close to it sooner or later.
    Quote Originally Posted by TurboMic View Post
    Jan 2011
    Mcalester,okla.
    4.56
    Sep 2010
    Im running 4.56 on my truck as well with 35" nittos. The only other ratio i would consider would be the 4.30's but only if I had to commute a lot with the truck.
    @J_Industries ON INSTGRAM
    TURBO MIC PERFORMANCE
    MAZZULLA OFF-ROAD
    KING SHOCKS
    [HOONIGAN]
    Apr 2013
    Weatherford TX
    I run 4:88's 2200 RPM at 70mph.
    05 Z71 Crew Cab 370ci LQ4 with ported and milled 317 heads and a 224/220 581/581 lift on 116 LSA cam
    Longtubes custom y pipe magnaflow cat-back,K&N CAI,4:88 gears, 7 in lift,20x10 Eagles with 35X13.50 Cooper Discoverys. Level 3 built tranny,40000gvw cooler and 2800 Torque Converter. Tuned by the best at BlackBear.
    Mar 2007
    Newark, Delaware
    4.56/4.88
