Results 1 to 10 of 12
Thread: Newbie from hattiesburg MS!
    Jun 2012
    I have a 2007 silver ado single can with the 4.8, shortie headers, K&N Cai with a base tune. What should my first mods be? I came stock with 323 gears and I was to do 373. Will it help?
    Arizona/Utah
    Get a good tune done, swap to 410 gears, and a stall from circle d.
    Search the threads
    Quote Originally Posted by Botlfed View Post
    Search the threads
    Lol what a warm welcome
    Go
    456 gears with Detroit tru trac
    Custom cam
    A stall converter
    Cold air
    Servo
    Pulley
    Nelson tune
    Sep 2011
    Welcome from laurel.
    Sit down and figure out what your final goal will be. Buy a good posi unit like the Truetrac or Valuetrac along with the gears you want to run. You will need to calculate what RPM you can live with at cruise RPM. LS based engines are notorious for oil consumption if you run high RPM, over 3000, all the time. Calculate what size tire and gear you're going to run to determine the RPM and gear selection. Once you have gears and LSD installed get yourself a convertor to match the power curve of the camshaft you want to run. Get a convertor that is somewhere around 500 RPM higher that where the cam starts to build power. Are you staying naturally aspirated or do you plan to go with a power adder like nitrous, turbo or supercharger? Everything but a turbo will like a nice set of longtubes.
    Mar 2011
    Mississippi
    Welcome to the forum from a fellow Mississippian
    * 2004 Chevrolet CCSB Z-71 5.3L * G80, 3.73's * Black Bear Autocal 91 oct tune * Magnaflow 3" SI/SO 14" case * Airaid M.I.T. * OEM airbox with open air modification * Color matched grille & lower valence * Blackened Tail Lights * SuperBright LEDs in brake lights & reverse lights *
    In the garage to be installed: 799 heads, Dyna-Tech long tube headers, Corvette servo, 2" lowering shackles, 2wd u-bolts & bumpstops
    Aug 2009
    Fort Riley, KS
    Welcome from Kansas
    Oct 2010
    Pearl,MS
    Welcome from Pearl MS!!!
    2005 CCSB Silverado- 5.3
    Airaid CAI
    True Dual Exhaust
    NPTune
    3.73 Yukon Duragrip limited Slip Diff.
    Feb 2012
    3.73's would be fine. Stall and cam.
