Results 1 to 5 of 5
Thread: 2002 Gauge cluster pinout
    Dec 2011
    Savannah, ga
    anyone have a diagram for the pinouts on the plug? i found the wireing schematic but there are a few duplicates of wires and i dont wanna fry this thing by hooking up the wrong ones.
    here is the connector
    Nov 2009
    SAN ANTONE
    Connector Part Information
    • 12110088
    • 24-Way F Micro-Pack 100 Series (GRY)
    Pin
    Wire Color
    Circuit No.
    Function
    A1
    TAN/WHT
    331
    Oil Pressure Sensor Signal
    A2
    WHT
    121
    Engine Speed Signal
    A3
    DK GRN/
    WHT
    817
    Vehicle Speed Signal
    A4
    BRN
    41
    Ignition 3 Voltage
    A5
    GRY
    1036
    Class 2 Serial Data
    A6
    BLK
    1850
    Ground
    A7
    GRY
    8
    Instrument Panel Lamp Supply Voltage - 1
    A8
    BLK/WHT
    451
    Ground
    A9
    ORN
    340
    Battery Positive Voltage
    A10
    PNK
    1020
    Off/Run/Crank Voltage
    A11
    Not Used
    A12
    DK GRN/
    WHT
    1932
    Transmission Shift Select Switch (Park) Signal
    B1
    LT BLU
    14
    Left Turn Signal Lamps Supply Voltage
    B2
    BRN/WHT
    419
    MIL Control
    B3
    DK BLU
    507
    Wait To Start Indicator Control (Diesel Only)
    B4
    Not Used
    B5
    PPL/WHT
    1382
    LED Dimming Signal
    B6
    PNK
    39
    Ignition 1 Voltage
    B7–B9
    Not Used
    B10
    DK BLU
    15
    Right Turn Signal Lamps Supply Voltage
    B11
    Not Used
    B12
    BLK/WHT
    174
    Low Washer Fluid Indicator Supply Voltage
    Dec 2011
    Savannah, ga
    wow awesome thanks!!!
    Dec 2011
    Savannah, ga
    tried to figure out where everything goes with the wiring schematics there are 2 that i'm unsure of though maybe someone else can shed some light
    • 12110088
    A1 TAN/WHT Oil Pressure Sensor Signal----Oil pressure sensor
    A2 WHT Engine Speed Signal----C2 Pin 10
    A3 DK GRN/WHT Vehicle Speed Signal----C2 Pin 50
    A4 BRN Ignition 3 Voltage----Hot in Run
    A5 GRY Class 2 Serial Data----C1 pin 58
    A6 BLK Ground----ground to body
    A7 GRY Instrument Panel Lamp Supply Voltage - 1---- not sure on this one
    A8 BLK/WHT Ground----ground to body
    A9 ORN Battery Positive Voltage----Hot at all times
    A10 PNK Off/Run/Crank Voltage----Hot in Run/Start
    A11 Not Used
    A12 DK GRN/WHT Transmission Shift Select Switch (Park) Signal----not sure
    B1 LT BLU Left Turn Signal Lamps Supply Voltage----left turn sig
    B2 BRN/WHT MIL Control----C2 Pin 46
    B3 DK BLU Wait To Start Indicator Control (Diesel Only)
    B4 Not Used
    B5 PPL/WHT LED Dimming Signal----dimmer switch
    B6 PNK Ignition 1 Voltage----Hot at all times
    B7–B9 Not Used
    B10 DK BLU Right Turn Signal Lamps Supply Voltage----right turn sig
    B11 Not Used
    B12 BLK/WHT Low Washer Fluid Indicator Supply Voltage----screw it
    Jan 2012
    Anacoco, La
    Any body have 1 of these for an 04 year model? I have 3 green/ white I need to know where they go.
