Results 1 to 10 of 13
Thread: 3" dual exhaust with x pipe!!!
    Round Rock, TX
    The truck is a 02 GMC and Ive done quite a bit of work to it over the past 5yrs or so. Its had air ride done which entailed having to be back halved due to another shop hacking up the frame. Its had a 6.0/80E swap and a Maggie put on. This last round of mods included ditching the shorties and mostly stock exhaust system. I installed a set of the stainless 1 3/4 TSP longtubes and fabbed from there back a true 3" mandrel bend system with a x pipe. The mufflers are 4" bodied Magnaflows and it sounds awesome at WOT, and yet you can keep a conversation going in the cab with no drone at all.
    Oct 2011
    San Antonio TX
    Damn thats nice. What would something like that run$
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    nice and clean
    Looks really good
    03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
    13' Sierra Denali 2500HD CCSB 4x4
    Thats almost the same setup that I am going to run, but I am going with 2 1/2" tubing. Great looking work!!
    Quote Originally Posted by TRPLXL2 View Post
    Why only 2.5"?? Aren't you swapping in an LS1?
    Sep 2010
    Austin, Tx
    Quote Originally Posted by RS/SS 4.8 View Post
    My thoughts exactly
    2008 RCSB AES built 390, prc ls6 stg 1 heads, fast lsxrt, comp 224/230 114+2, circle d multi-disk 3200,built 65e, 3.73's, lt's no cats, 18" magnaflow dumped, D1sc, alky meth kit, efi live tuned by me...hold on to my drawers Some new goodies on the way ...
    Oct 2007
    Bandera, TX
    Beautiful as usual. Good job
    single digit street truck
    for build info
    Looks very clean!
    I did a set up like this on my buddies 06 SS, it was a mutha getting long tubes, cats, and dual 3" pipes to all fit in there. Only way I got it to fit was by making a tubular trans crossmember.
    The Fleet...
    2003 Suburban- 5.4 L59 331CI 10:5.1 Compression -Built by ME
    2004 Avalanche- 5.7 LS1 -NOT built by me
    2005 Silverado RCSB- 5.7 LS6 -Built by ME
