Results 1 to 10 of 13
Thread: Best way to bring 12 year old Canadian paint back to life?
    Ottawa, ON
    Gonna try and tackle doing a detail job on the truck this weekend. It has been sitting for 3 years and the paint is fading a bit with surface scratches. I've waxed it before and it brought it back to life. I really want to do the best job I can to get it to look the best it can get. I've heard of clay bar, wet sanding etc but never tried it. Any suggestions on what to try? Suggestions on the technique to go about it would be great too!
    Dec 2008
    South Carolina
    ^^^sexy
    My boyfriend is a retired body man after 30 years, all he uses and swears by is WIZARD products. This cannot be applied by hand, It must be buffed with a buffer. I can tell you this, that stuff is like magic. He buffed out my 90 Lumina last summer, and it's all original paint and clear coat (torch red). It is a two step process, first step is Wizard rough cut, and second step is Wizard finish cut.
    Adam's Polish does work good, but you'll be an old man by the time you get it done.....Too much manual labor for me, learn to use a buffer
    You use a machine with Adam's. I can do a FULL complete paint correction in an afternoon. So, No, he won't be an old man.
    Pittsburgh, PA
    i find that hard to believe unless youre talking about small amount of sheet metal. Just claybaring a vehicle properly takes along time. Crew cabs deffently arent an afternoon job
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    To be fair I consider it afternoon until the sun goes down, but yeah. Crew cabs, no definitely not an afternoon. But a little regular cab? You can move pretty damn fast. Sure there's a lot of acreage to cover, but it's all flat easy going. And it depends on the condition of the vehicle I'm starting with. I should've said I can do MY truck in an afternoon, as it's been cared for since it was new.
    Feb 2012
    Mcalester ok
    I just done mine but it ain't old paint. I wet sanded with. 3000 grit paper then used 3m three stage compounds with highspeed buffer. Oh and it's a crew cab.....very time consuming 
    I have a 90 Lumina eurosport that has the original paint, which had a lot of roughness on the surface on the paint just from age. I clay barred the whole thing, and just that took me about 30 hours, but It was well worth the effort. The clay bar takes a lot of the impurities off the surface of the clear coat, good luck with your truck and take your time.
    Mar 2006
    Indy
    Just waxed my extended cab. Took 45 minutes. My arms have a little soreness. I need a buffer.
