Results 1 to 10 of 11
Thread: e-fan install pics?
    Jul 2010
    Douglasville Ga
    e-fan install pics?
    From my searching here, I gather that F body ls1 fans with 28" obs radiator and 05+ truck fans with 34" rad are most popular. Three questions:
    Anyone mind posting install pics of one of these setups or some less popular OE setups? I am not interested in any aftermarket pics. I am dead set on creating a very factory looking install.
    Next, this is for the 92Sierra swap. LQ4, cnc and welded chambers 317 heads, cam, springs, push rods, LTs, dual 3" with Magnaflow X muffler, 80e, stall vert. Don't know compression ratio yet, maybe 10.5? Don't know cam specs or stall speed. Heads are at Advanced Induction getting worked and soon they will release cam specs and stall recommendation.
    All that said, what are your opinions on rad sizing. 28"obs or 34"? Is a bigger rad TRULY necessary? Fans will be wired for two speed. He is in Ga where summer time temps do reach 100°.
    Also, has anyone kept the factory obs fan shroud with either of the above popular fan/radiator combos. I would love this if its possible. Thanks guys! Pics please!
    not the best pic, but here's my F-body fans mounted to my factory 34" radiator.
    the bottom of the fans set on the core support & i made the 2 top brackets from some aluminum.
    Sep 2011
    Quote Originally Posted by RPM Graphics View Post
    You just wanted to show off that engine bay! Lol looking good!
    Jul 2010
    Douglasville Ga
    Thanks rpm. Looks good, but I hope I can come up with something a little more factory looking. Still wonder if ls1 fans would fit under the shroud? Happen to know the ls1 fan dimensions? LxWxH? Thanks again!
    i can put a tape on them tomorrow. i plan on doing some aluminum work to make a cap for the top & like a shroud to cover more of the radiator.
    i still have my old shroud & even if you cut it to fit i don't thing it would look good. i think it's too bulky & would take away from the look of the motor.
    Jul 2010
    Douglasville Ga
    Don't want to rush or sound ungrateful, but have you had time to measure your fans? Thanks man!
    Jan 2010
    Moore oklahoma
    I came up with 28.5 wide by 18 tall.
    2001 Silverado, work in progress. Add a vette servo and Nissan e-fans
    Attachment 7160
    This is my radiator support out of my 04' Colorado, those are 99-02 F-body fans for my application it would work great!! I don't have measurements, but I could get them if you need them.
    overall mine are 18" tall x 27"-28" wide (28" to the widest tab) the fans are about 11".
    Jul 2010
    Douglasville Ga
    Thanks guys! Guess ill do 28" rad and f body ls1 fans. Not exactly the look im going for but I suppose it will be fine. I do appreciate the help and pics!
