Results 1 to 10 of 12
Thread: DBRODS Fuel Cell A+
    wichita falls, tx
    DBRODS Fuel Cell A+
    Just received my fuel cell from Jon today. I must say it is beautiful, Welds are perfect and it seems like it is just built to last. I'm not sure what kind of aluminum or how thick it is but it is some thick stuff. I had him make it a little bit different than normal because it is going on a bagged truck so I didn't want to run the risk of dragging it.
    Here are a couple of pictures after i pulled it out of the box, I will get more up tonight of it mounted in the truck.
    blanco,tx
    Looks good! I'd like to see what the inside looks like (baffles n such)
    Ottawa, ON
    Looks good, love the welding job Jon.
    Houston
    Quote Originally Posted by twodogs View Post
    Its using a stock bucket, no need for a baffle.
    Round Rock, TX
    Thanks Trey. You are correct about the material being thick, they are built to last in street applications. Total weight I believe was 40lbs.
    wichita falls, tx
    No baffling just like Luke said because its using the stock bucket. It def should last I was impressed at how solid it is.
    Jan 2007
    Crandall, TX
    Here is photo of the baffles in my Dbrodz fuel cell
    06 CC 4/6 drop
    Oct 2011
    San Antonio TX
    Those r nice. Might need u to build me one for our LS10 conversion John.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Boss
    nice cuts, done with a circular saw?
