Results 1 to 10 of 15
Thread: 1994 5.7 to 5.3 lm7 swap
    Mar 2012
    Im new here looking for input on swapping a 5.3 with 4l60e into a 1994 silverado 4x4 that currently has a 350 tbi and 4l60e. The tranny is on its way out so I figured I may as well swap on a new one while im at it. Motor mounts... wiring harnesses... these are things ill need help with most. I haven't started the swap since the truck is my DD but im looking for info and approximate cost for a swap. Ive found a 5.3 for 650 with harness and ecm and a tranny for 750. Is this a good deal? Ive also been told that the ls style AC bracket and compressor won't clear my frame... is this correct? Any info greatly appreciated.
    dont rush it. do as much home work as possible.. im about to drop my 5.3 out of a 2007 chevy in my 92 p/u 5 speed..after 3 months. lol this site helps alot all you gotta do is look and ask .
    Mar 2012
    Yeah... ive got ALOT more homework to do!!! lol in the past month ive learned alot but im gonna keep plugging along and hopefully ill get enough knowledge and nerve to do the swap!
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by Clayman View Post
    Basically did the same exact thing...my tranny was goin out so i did the 6.0 swap with 4l80e. Plan on spending atleast another grand than what you had intended lol thats all i have to say.
    Silverado Z71 10" Lift COMPLETE 6.0/4L80E PRC 2.5 Ported LS6 Heads 228r Comp Cam 3200 CIRCLE D Stall LS7 Lifters ARP Bolts SLP Oil Pump and Double Timing Chain 160 T-Stat 3" SLP Loudmouth Electric Cutout Walbro 255 Pacesetter Longtubes MSD Starter NELSON Harmess NELSON Street/Strip Tuned ECM MSD Wires LS1 Throttle Body Braided Lines Spectre CAI 4.56 Gears Detroit Locker 14 bolt http://www.ls1truck.com/forums/lsx-t...wap-build.html
    Mar 2012
    Yeah im counting on it. lol can I use my original transfer case with the 5.3 setup? Im assuming I can since its the same tranny...
    Sep 2011
    Atlanta Ga
    yep just make sure u take the 4wd low signal and put in ur ls pcm.
    Jan 2012
    Quote Originally Posted by myzterray View Post
    What does that do?
    Mar 2012
    Ok I should have said earlier but its the manual shift style... does it make any difference? Sorry all the questions I just have alot of stuff to figure out....
    Sep 2011
    Atlanta Ga
    I have no idea about 5 speeds..I can barely drive one lol. It's cool to ask questions..that's why ur here..I gained almost all my knowledge about the swap fro. This forum so ask away...
    Mar 2012
    Its an automatic tranny but manual transfer case... sorry if that was confusing
