Results 1 to 8 of 8
Thread: drop shackles
    drop shackles
    Anybody having issues with ride quality with 2 inch drop shackels on nnbs? Im considering leveling my truck and wanted to know bout ride quality and quality of different brands of shackles. Thanks
    ride quality is fine. take the rear block out too and it will sit level if yoiu don't it will still sit hiked up in the rear
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    Nov 2011
    I bought the drop Shackles from Autozone and removed lift block and my rear is 1/2" lower.
    MY TRUCK IS A HYBRID!!! IT BURNS GAS AND RUBBER....
    2011 GMC CCSB
    Flaco Tune, CAI, Muffler
    13.8 @100
    340hp 352tq
    im assuming you meant your truck was a 1/2 inch lower after the removal of just the blocks.... right? lol
    Nov 2011
    Quote Originally Posted by 1lowbird View Post
    Nope. I installed the shackles and removed the lift block and my front is now 1/2" higher.
    2011 GMC CCSB
    13.8 @100
    340hp 352tq
    gotcha
    Mine sits just fine in my opinion sir
    Mar 2007
    Newark, Delaware
    Remember that when you raise one end of the leaf spring, the truck is lowered by half the amount the end of the spring was raised. I thought I had 2" shackles on my truck, but I measured them and they were 7" center-to-center. Stock shackles are around 4". So I raised the rear of the spring 3", effectively lowering the truck about 1.5". Just wanted to let you know that a lot of "2 inch" shackles only yield 1.5" of drop.
