Results 1 to 10 of 19
Thread: New Project - 06 Colorado to '09 G8 L76
    Jan 2012
    Started a new truck for a customer the other day. Figured I'd post progress pictures and try to document the process on here for folks.
    Truck is a 2006 4 door 2WD Z71 Colorado I5 Auto.
    Engine going in is a 2009 Pontiac G8 L76 engine and 6 speed auto trans.
    Scored this setup at a local yard with 7k miles on it.
    Got the engine out the other day in about 4 hours.
    Spent a little bit of time today switching over the C1(Blue) connector you can see on the pass. fenderwell for the newer style connector that will be used on the new computer. Engine is a 58x motor, so we will need a computer like the '09 Colorado V8 uses.
    Ordered a set of stainless headers from OTTP. They are supposed to fit, so we will find out.
    damm thats gonna be nice
    Okay I'll ask the dumb question,what is bolted to the tailshaft of the transmission?
    Pontiac drivetrain in a Colorado.................SWEET!!!!
    Oct 2011
    San Antonio TX
    Yes that colorado is gonna fly.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Jan 2012
    Finally got the engine set in place.
    Got the headers over to the coaters
    Been working on the transmission crossmember and finishing up the wiring.
    Test Fitted the engine cover!
    Sep 2011
    Atlanta Ga
    do you plan to color matxh the silver part of the cover with the truck? that would be badass!
