Results 1 to 5 of 5
Thread: Heads and Injectors
    Nov 2011
    Heads and Injectors
    Is the three digit code on aluminum heads how to identify what you have? Where can I get info on head identification for stock chevy heads? Still need to know how to determine what size injector to use when adding turbo,supercharger,etc.Thanks
    Two sets of heads "853" and "706"
    Arizona/Utah
    Yes 853 and 706 are mostly the same head and they come on 4.8/5.3 motors. As far as injectors need more info on the build because it could be anywhere between 42lbs and way bigger.
    Dec 2004
    San Antonio, TX Area
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Very wrong.
    862 and 706 heads are very similar. Only difference being stand cast for the 862's and semipermanent molds for the 706's. Sand cast has a slightly more rough surface than the spm cast which results in a minuscule drop in flow rate.
    The 853 heads are the same heads as 241 which came off the corvette. They have larger valves and a larger CC and flow fairly poorly.
    Arizona/Utah
    Woops my bad thought he was talking about the 862's oh well looks like he didn't care to check back anyways
