Results 1 to 10 of 12
Thread: engine startup and no oil pressure... NEED HELP!!!
    Nov 2011
    NH
    i swapped a 6.0 into my 1500. and i got a comp cam and put that into it with comp valve springs also. and put a summit double roller timing chain set on it. and when i got it into the truck and started it. it makes a aweful noise when it starts just sounds loud. and then it says no oil pressure. i only had it running 5 to 10 seconds at most. just wondering what i should do to check if somethings wrong or if oil just hasent got thru the engine yet. let me know what you guys think!!!! THANKS
    Since u didn't touch anything near the oil pressure sending unit or gauge cluster doing this job, I'd assume it's the oil pump and tear it back down immediately. Did the double roller have different selections for cam advance and retard?
    U didnt describe the noise as being clatter, grinding, squeeling or whatever. How'd it sound?
    If u really only let it run for 15secs with no oil pressure nothing got hurt.
    Id put a new oil pump on it and. BE sure it's installed correctly.
    Also. Not really noise related but a cam bearing could have fallen out, that would cause low oil pressure
    Bet it's the o-ring on the pickup
    Nov 2011
    NH
    it just it a loud grinding i guess would be the word. but i think im gonna check that o ring and then get a oil pump just to be safe. i dont want to do any damage to the motor. and if i try to start it more im afraid i will. where is the o ring located??? on the pickup in the pan??? Thanks guys!!
    The o-rin is on the pickup where it goes into the pump. They're a fairly fickle thing, you have to be careful with them
    Mar 2007
    Newark, Delaware
    It took my 6.0L 5-10 seconds to build oil pressure when I swapped it in. Try pulling the spark plugs and unplug the injectors and cranking it over to see if it builds pressure, unless you have reason to believe its a bad pump or o-ring.
    Okeechobee, Fl
    This is what im thinking. Its what happened to my 6.0 when i swapped it in my old truck. engine sat with no oil for too long and the o ring dry rotted. Put new o ring on, problem fixed immediately.
    49 Ford F1
    Oct 2007
    Bandera, TX
    Makes sure pump is center on crank. Very important. And make sure double roller clears the back of the pump.
    you need to slot the mounting points on the pickup tube so that it moves forward to meet the new mounting hole location.
