Results 1 to 9 of 9
Thread: Engine build gone bad
    May 2007
    Phx ,AZ
    I had a local machine shop put together a turbo motor for me and the rings never seated. The motor had blow by like there was no tomorrow. Motor only had 2k+ miles when it got pulled from the truck. I took the motor back to shop that build it and they couldn't figure out why the rings didn't seal.
    Block 2000 LS1
    Piston Probe SRS 2618-t6 wall to piston clearest is .004
    Piston size 3.898 bore size 3.902
    Top ring gap .024 second ring gap .032
    Here are some pics of the cylinder walls. The wear marks are very smooth and all 8 cylinders look like this.
    Some pics of the piston skirts.
    Let me know what you guys think.
    Truck 2002 Chevy with
    old setup KB turbo kit MP70 LS1
    New setup stock for now
    sorry to hear that....
    Round Rock, TX
    alot of the piston skirt marks could be from trash still in the block after assembly or if they didnt radius the bottom edge of the cylinder wall. After boring/honing it becomes very sharp at the base of the cylinder and needs to be cleaned up, if not then when the piston skirt travels below the cylinder bore the sharp edge digs into the piston...
    May 2007
    Phx ,AZ
    The edge of the cylinder feel like it has a little bit of edge.
    Dec 2008
    South Carolina
    iv heard if you run synthetic oil during break in period the metal parts wont mate to each other properly...dont know if this is your case or not
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    May 2007
    Phx ,AZ
    Quote Originally Posted by chvy=power View Post
    I used conventional oil.
    Sep 2010
    Dang sorry to sed this.
    Arizona/Utah
    Which machine shop built it?
    May 2007
    Phx ,AZ
    Machine shop in Mesa. If you want more if pm me.
    Thanks
