Results 1 to 10 of 44
Thread: NA cam VS FI
    NA cam VS FI
    I was just wondering what makes a good na cam vs a good Fi cam. becuase i see guys runing 112 lsa lots of duration and high lift with turbos, my thought that was a good na cam. So FI i thought you want a loose lsa and high lift. Someone clarify for me.
    The overlap + LSA is what is important.
    I did the cam calculator and i if i remember right it said my cam had negative over lap. specs are 112 218/227 in/ex 525
    Pittsburgh, PA
    untill you start seeing over 1k hp then the cam isnt as important as some may think. Hell i used a trex and had no issues with spool or boost....theres alot of myths out there that get passed on from ppl to ppl, then ppl live by those. its actually the ppl who think outside the norm are the ones usually with great success...it just took a few trys to get it right were as others just follow
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Quote Originally Posted by Quik View Post
    so what your saying there really is no FI or NA cam. Ino some could work better then others but wouldnt a cam with alot of over lap bleed boost?
    BTW it said my cam has -1.50 overlap, ino what overlap is but what exactly is the 1.50 degrees?
    Pittsburgh, PA
    it all depends on what your shooting for. Id rather have some overlap then neg for something that is going to make big power. If i was going to boost something heavy i would defferently spec a cam differently then a RCSB or even a fbody. Spend some time on sites like theturboforums, yellowbullet and the FI on tech. youll see certain ppl replying about using cams with overlap and there success. in a blower situation youll bleed boost but a turbo setup will still make boost as its regulated by the wastegate. if you dump the boost into the exhaust youll spool faster. bleeding boost also helps reduce back pressure allowing more rpm and resulting in more power.
    Quote Originally Posted by 6.0vortecchevy View Post
    412 Motorsports
    so would you say my cam is a better blower cam then turbo?
    Pittsburgh, PA
    for a heavy truck that cam should lite the turbo pretty well and have a tight power band...least how i see it. not something i would use for my RCSB but something like my crew id use it
    412 Motorsports
    S.A. Texas
    What he said, just go BIG hell the TU2 is a turbo cam with a 112 lsa IIRC
    Dec 2008
    South Carolina
    Pat G specd a cam for my turbo set up and it was a 218 218 .565 .565 116+1
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
