Results 1 to 8 of 8
Thread: help needed with shifter rod issue
    Dec 2008
    san antonio TX
    i was using the stock manifolds on my 82 c10 LS swap, but i recently bought some 2002 ls1 camaro headers the pass side fit good, the problem is the driver side. the header fit but i cant shift into gear because it hits on the header collector. i need opinions on how i can get this fixed. im gonna cut the collector and weld it straight but its still not enough to clear the shifter rod. heres a pic
    Move the shift linkage over sideways.
    Dec 2008
    san antonio TX
    how can i do that, sorry im clueless on this.
    the linkage arm is bent towards the trans, bend it towards the frame rail.
    Broken Bow, OK
    Lokar makes a linkage cable kit that would work. I used the same kit on a 70 C-10 when installing a 4L60e and headers. Eliminated the rod linkage.
    Dec 2008
    san antonio TX
    i just looked up the cable shifter, if i cant get this one working im gonna try it out. thanks oh also how does it mount to the steering colum? do i have to take it all apart?
    so, do you have the selector rod or cable? Now I'm totally confused.
    Dec 2008
    san antonio TX
    I have a selector rod, the one in the pic. im gonna take your idea and get that arm closer to the frame. if i cant get it working than i might have to buy a cable shifter as pitchblack said.
