Results 1 to 7 of 7
Thread: Changing the fluids this weekend, new some tips on what to choose (Diff, Trans, &Oil)
    Question Changing the fluids this weekend, need some tip on what to choose (Diff, Trans, &Oil)
    I use to go with Mobil 1 synthetic for my oil but now I've heard they switch to a different base oil which changes it up or some sht.
    1) What brand oil do you use and what weight? I know I will probably go with 5/30 like usual and won't ever change. Probably going to buy Royal Purple if Autozone has any.
    2) How many quarts do I need for the trans and what brand/weight do you use?
    3) How many quarts do I need for the diff and what brand/weight do you use? Do I need the G80 additive too or is there a double mixture with the diff fluid that already has it?
    Colormatched/NELSON Tuned/DMH cutout/Magnaflow/Vette Servo/Stockers/ 4/7 Dropped/Pacesetter LT's
    31 Views, 0 replys.
    Come on guys, there isn't a wrong answer here lulz.
    I use Valvoline full synthetic. My grandfather, father, and uncles are swear by it so I use it too. I like it because its cheaper than Mobile 1. I do use a Mobile1 oil filter though. Autozone had a deal going for a while that was like $30 for 5 quarts and the filter. I use 5.5-6 quarts. Use to burn a quart every 1500 miles which stopped after switching to synthetic. Just for reference this is in a 2k sierra 4.8L
    http://www.ls1truck.com/forums/racer...ion-fluid.html
    there is your answer on trans fluid.
    In other words I should have searched more for my answers lol
    Thanks Kerrige
    Quote Originally Posted by 08Chevy View Post
    Thanks Kerrige
    You prolly the case. I am just not a dick about it.
