Results 1 to 10 of 13
Thread: 4l60e vs 4l80e dimension differences
    Dec 2010
    orange county, ca
    im looking to swap my worn out 60e with an 80e and have a couple questions.
    1. are there any differences in obs and nbs 80e's like there are with the 60e's?
    2. will my transfer case bolt to the 80e or do i need to get a new one?
    3. and will i need to resize the driveshaft lengths and move the crossmember?
    4. lastly will the shifter linkage work the same?
    the truck is a 94k1500 so it has the old hardware instead of a cable.
    any input helps, thanks
    95 rcsb, built for the desert, sbc w/edelbrock mpfi, custom front long travel 18in travel, rear 4 link 29in travel.
    94 ecsb, daily driver, 6inch rcd lift, 350 pending 6.0 swap, 14 bolt also on the way
    Broken Bow, OK
    2. The output shafts are different for the 60 vs 80. You will have to get a different case or swap the input on yours.
    3. Yes, the 4L80e is longer
    4. Usually, yes.
    Dec 2010
    orange county, ca
    ok, thanks.
    Mar 2011
    I think the 80 is much larger in size. I know it's much heavier 4L80 is 220 pounds.
    Dec 2010
    orange county, ca
    yeah, i think im having a change of heart. just gonna go with a stout 65e
    Quote Originally Posted by chevyguy1450 View Post
    You will be back if you make any power.
