Results 1 to 10 of 15
Thread: measuring cam base circle
    The Garage
    I'm trying to figure out what length pushrods to use and I wanted some opinions on the method I'm planning to use. I figure I'll take a micrometer to the stock cam's base circle, then do the same to my comp cam. I'll compare the measurements and hopefully be able to determine the proper length pushrods from there. What do you guys think? Could this yield the proper length pushrods or am I just crazy?
    Why not just call the manufacturer of the cam and ask?
    The Garage
    Way ahead of you. I already called them and asked. They don't know and said it's because the base circles are all different
    Quote Originally Posted by jetmech View Post
    Good call... doesn't make sense though. If the base circle is different on all their cams with the same grind... that's no bueno.
    The Garage
    No kidding. According to Comp Cams, the biggest reason different length pushrods are usually needed with a different cam is because the base circles are rarely the same as stock. Hence the reason so many people use different length pushrods with big cams or adjustable rockers. It sucks ya, but the engine is still getting built so I still have some time to figure this one out. Still, am I on the right track with measuring the base circles?
    If it's the cam you bought from me, it jives with stock length pushrods.
    plumbed incorrectly? 3/8" side should be from the pump and 5/16" is return to the tank.
    Wrong thread Greggo.
    damn links!
    The base circles vary due to lift and duration. They can only cut a lobe so tall before it will not be able to fit through the bearing bores so they get the height of the lift by reducing the base circle.
