Thread: Anybody else have the same problem with passenger side front door speakers?
    Oct 2007
    connecticut
    Question Anybody else have the same problem with passenger side front door speakers?
    Ive own the truck since 2003 and every 2 years or so, the passenger side front door speakers will stop working. doesnt matter what i put in there, Rockfords, Infinity's, etc. My best guess is that water is getting to them some how but they usually dont look bad when i pull them out. Sometimes ill be driving and they'll quit for a couple of minutes then ill hit a bump and they come back. ive checked all connections and usually i can get it to do it by fussing with the speaker itself. A new one always solves the problem for a year or two.
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    Wichita Falls, TX
    It definitely sounds like a connection or grounded wire somewhere. If all else fails you can always run new wire from the radio to the speaker. Are you soldering your connections? or using the junk crimp connectors? if you are using anything besides solder, that could be your problem. It could also be corroded wire (I've seen it in about 80% of the vehicles I have put speakers in)
    Yep fixed it last week, was crimps in the door
    Psalms 144:1
    Si vis pacem, para bellum
    Sep 2011
    New Orleans, La
    +1 for solder!!!
    If you're not first, you're last.
